Patrick
Patrick's Avatar
10.05.2007, 06:00 AM
Maybe a long skinny piece of sand paper looped around the shaft? You could use coarse stuff to start, and finish off with a finer grit to make it nice and smooth.
10.05.2007, 10:59 AM
Sand paper tends to wear off the backing fast, and is not that great on steel, I figured that the grinding wheel material(stoone-like substance) would work the best. As it wears new abrasive is exposed, and it should wear evenly, to keep the shaft diameter the same along its length.
