Thread Tools Rating: Thread Rating: 4 votes, 4.00 average. Display Modes
10.06.2007, 06:57 PM
According to the pic you posted, if those are modified 3.3 axles, then the threaded portion is cut off, then the groove is milled into the center, and then a hole is drilled at the other end(that goes into the diff). The diff out put gear is held on by a cross pin that slides thru the newly drilled hoe and the output gear has a slot milled in the backside that the pin engages onto. This is just the same as stock HB, so the pin and output gear are un-modified. It could be done by hand, however the hole would have to be drilled prescisely thru the center of the axle. Not sure if you really need the groove, but I think it has something to do with the o-ring that seals the fluid in the diff.
ClodMaxx
hold my beer... watch this...
ClodMaxx's Avatar
10.06.2007, 07:02 PM
newly drilled hoe
must.....resist.....commenting.........
Eflite Blade 400 heli on 3s
10.06.2007, 07:06 PM
Sorry meant to say "freshly drilled hoe"
Glad to see that people are reading my posts!
mkrusedc
NeuMaxx
mkrusedc's Avatar
10.06.2007, 07:24 PM
You guys make my day...
Tags
bullet proof, diffs, emaxx, hotbodies, unlimited engineering
