AAngel
10.08.2007, 03:41 PM
I know, I know. I can kill anything. I think I'm going to get another 1512/1.5y though. It's a beast of a little motor.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
10.08.2007, 07:29 PM
Yeah, my 1512 motor flies on only 7 A123 cells, imagine what it could do with 6s lipo's like flightpowers, they really come alive when you feed them the voltage, and don't break a sweet! This makes me want to buy some flightpowers, AAngel, do you know of a 6s lipo pack roughly 3000-4000mah range that would only droop to 3.6 volts under ~70-80 amps? The more I run my 7s pack, the more I feel the voltage dropping way too much... making it hard to get 'consistent' driving feel, and a lot less power potentially than a good lipo pack.
jhautz
jhautz's Avatar
10.08.2007, 07:50 PM
I had the motor shaft break loose on a Neu 1512/2.5d once as well. It happened the first time I ran the thing. Neu was really fast about getting a replacement back to me. They had me send it in to Diversty Model Aircraft and they had a repaired/replaced one back to me in a few days. I never did find out if they replaced it or fixed it, but either way... it was all good. No problems since.
Even the best comapnies can make a dud on occation. But AAngel does seemsto be a Dud Magnet. Or just the guy who pushes stuff the hardest and finds the most weak points.
to make it...
or break it...
Silent...But Deadly
gixxer
gixxer's Avatar
10.09.2007, 06:44 AM
I run the same 1512 3d on a 5s enerland 4350mah pack and its plenty fast for me. For the track I only run it on 4s though.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
zeropointbug
Z-Pinch racer
10.09.2007, 01:08 PM
Oh really? Cool, I wonder what it will be like on 6s Flightpowers? (Enerland)
You are probably getting the same performance as I am on 7s A123 pack.
