sleepy23
sleepy23's Avatar
08.03.2005, 11:19 PM
you know, that would prolly be great if mine would program at all. I am utterly dis-satisfied with my results on the mgm, i guess i must be too dumb to progam it (will explain in a second), what do you have that will handle like a lehner 5300, is programable via computer (or simple like novak), and doesnt need a reciever pack???
now with the mgm80 programming....
i do just what it says to get into programming mode:
turn on radio hold FT, then turn on controller
after `10 secs, it beep 3x, then go FB for 1 beep, then neutral and 1 beep
when i go back to neutral, i get 2 beeps, so i dont know where i am or what it is doing.
normally not such a big deal, it runs, but with issues with it braking and backing up on its own and then i now have the 2s pack i want to run....i need some major help in figuring out what is going on, or what i can replace this pos with.
i will appreciate any help from anyone on this issue....also if anyone could use a SLIGHTLY used mgm80 and 6s motor....
S^3: everyone wishes they could design modifications like these.
