mothman
10.23.2007, 09:43 PM
cool!! I'll PM you later with the size that I need. Thanks alot!!
rchippie
rchippie's Avatar
10.23.2007, 09:52 PM
No problem im thinking i could cut 10x10 or 12x12 squares. then you could make what you want.
REAL MEN RUN BRUSHLESS
JThiessen
JThiessen's Avatar
10.23.2007, 11:45 PM
Hey, I'd like to get a couple 12 x 12's of this. Also, If you can get a spec on on it, we may be able to utilize this at work......
Sent you a pm....
10.24.2007, 12:02 AM
Would this kydex be easier/better than lexan to make battery trays out of? I have tried a few times to make the trays out of lexan and it worked ok, but the lexan does not bend too easily, even with heat. Do you glue the sides where thay meet up?
rchippie
rchippie's Avatar
10.24.2007, 07:51 PM
Yes i think there are alot eaiser to make with kydex veruses lexan . No i used right angle aluminum to make my end caps. Check my ERT pics that i posted in this thread, for ideas.
http://www.skellyo.com/hippie/
YOU GUYS DO KNOW THAT MIKE CAN MACHINE CUSTOM BATTERY TRAY'S FOR YOU.
ssspconcepts
ssspconcepts's Avatar
10.25.2007, 11:46 AM
RCHippie, I appreciate all the info and the offer. I probably will take you up on the offer...I just don't have some of the tools & materials required for a clean finish (i.e., specifically the band saw and aluminum end caps). I did send Mike an email asking if he could make me a battery tray but he hasn't answered back yet. I also asked him about some other odds and ends awhile back and haven't had any luck with those either.
