Dagger Thrasher
I have no idea what's going on
Dagger Thrasher's Avatar
10.24.2007, 06:19 PM
That's a very good point...if it was simply a case of reprogramming the Hydra and whacking on a heatsink, Castle would have already done it IMO...or be in the process of doing so. It's probably nowhere near that simple. The MGM controllers are most likely designed around handling what a car dishes out primarily, and then has alternate software for boats. The Hydra controllers are primarily boat controllers, and I'll bet cars put a bigger strain on ESCs than boats do.
As for voltage... around 40V and above can kill a person if they directly contact it. So it's never going to be a setup that a lot of people use...
lutach
lutach's Avatar
10.24.2007, 06:48 PM
Look at the Kontronik. They don't have a heat sink. One of mine does and the rest doesn't. Joe said they will have a 60, 120, 180 and 240A versions. This would be fine for a car. My point is they could have gotten a hold of another market by simply adding a car mode to the controller. The only Kontroniks I know that is over 100A is the Power Jazz and those FIA controllers and they don't have a car mode. All the rest does and they work fine. I have a 30A Kontronik that I tried in my touring car a few years back and it ran perfect. If a HV system is set up perfect, it doesn't see spike of 120A+ anyways. If Castle adds a car mode it wouldn't hurt at all. They could benefit from it with sales to us car guys. BTW MGM's 9044 controller can be programmed with a car mode. This information was sent to me from Ing. Grisa Dvorsky. That is a 90A originally for Airplane that can handle 15S lipos. They have the Z series and the EXPERT + available.
