I'd do a little research on here before going for that combo... I'd either do a mamba max with a feigao or look at the mgm 160 with the nue...
The MM does not like the 4 pole motor design of the Nue - Lots of cogging I believe... It also is quite high KV - Most would run something a little slower with 4s which is fine on a MM with a UBEC.
Just my 2c but read on there is a lot of info here!
