RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
11.03.2007, 11:12 AM
You could implant the entire Hot Bodies LSP center Diff setup(spur and center bulks with the LSP mount) if you wanted, but then you wouldn't need a Mugen mount at all.
The idea is to make a motor mount for the Mugen itself - using the entire Mugen diff and front center bulkkhead with one of our hardened pinions. No need to buy anything else - just the motor mount and hardened pinion. The whole Hot Bodies diff and plastic spur setup is a "work around" when not using a hardened pinion.
The Mugen mount will allow you to use all the Mugen parts instead of transplanting parts from other vehicles. Same idea as all the rest of our mounts. :)
