yah it was that i needed to flip the diff's and i tired to switch the wires but it did not work. but that day i locked it into second lol. so i did a lot of work that was not needed lol.
but its all cool i was showing it off at work today and i broke a lot of stuff. like the 1 spur gear, 3 wheel hex's, 1 front diff, 1 push rod, and 1 rpm arm lol.
i did not konw that a poll could do so much damage haha. but its all fixed and its good. i got to try not to brake it any more cause i dont get paid for 2 more weeks and today was an expensive day.
oh yah and i broke the tekno wing mount cause i was doing backflips off of the curb. hahaha
also just wondering would betting the whole tranny gears in metal by robinson racing be better since i feel like the gears in the trany are going to just strip
also if i get that would i still be able to lock it into second?
Wow! Thats like asking which Neu motor you should buy. Its a matter of opinion. Some people like plastic and others like metal. I personaly like plastic. usually only 1 gear breaks or strips. Cheap fix. But if you have metal gears the pressure that would break a plastic gear has to be transferred else where. If you buy metal gears the pressure that would break them will be transferred to break something else. What would break, who knows. You need some cheap plastic parts to take the beatings sometimes.
Well, are the RPM arms at least a little bit stronger than the stockers? I just tore the cantilever link out of the "driver's side" front arm. Hopefully stockers will hold up next time.
I only use RPM for my plastic arms. I use aluminum for lower arms though. Never broke any arms yet.
the rpm ones are stronger then stock. cause i know if i had stock ones on it would of tore them off when i hit the poll
also on the gears i was just wondering if any one had used them and was able to lock the second still. i think i might just still with the stock ones just because its like 100 for the gears lol.
