Thread Tools Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
sikeston34m
sikeston34m's Avatar
12.04.2007, 08:56 AM
http://babelfish.altavista.com/ is a good translator.
Just copy and post the PowerCroco url to it and you can navigate the website in English.
Pretty cool
sikeston34m
12.04.2007, 09:02 AM
I thought something looked funny about the german guys wind in thinking it was a wye termination.
After reading some more, it's a Delta winding. He just made the connection across the stator by soldering.
sikeston34m
12.07.2007, 12:04 AM
I'm waiting on my 200C 22Ga. Winding Wire to come in, looks like it's going to be early part of next week. *sigh* The AXI 4130 is just sitting here waiting.
In the meantime, I have spotted a couple of motors to practice winding on. They are outrunner motors that I've used with the E maxx.
One is the 650kv that I do the E maxx outrunner conversion with. The other is a discontinued Lightning 600 Helicopter motor that I was running an E maxx with.
I just unwound a Lightning 600 stator. It was wound Delta DLRK style with 20 strands at 5 turns per pole.
The stator on this motor is 35mm in diameter and 30mm long. Each pole was really full wound this way. It's a little puzzling to me because this motor was rated at 715kv. Being a 5 turn motor, It seems like the kv rating would have been much higher than this.
@JohnRob - Did you get your wire ordered?
johnrobholmes
johnrobholmes's Avatar
12.07.2007, 02:43 PM
I haven't ordered wire yet, and I still have one last phase to wind on my 3032. I fell on my head monday so I can't really do anything if front of me for very long periods of time yet.
the kv on that 3530 seems about right. 5 turn delta, big and long stator. The bigger or longer it gets the slower the motor will spin with any given wind count and termination.
sikeston34m
12.07.2007, 03:17 PM
OMG, Are you ok? I hope so.
With the 4130, I'm thinking about a 4 turn Wye with the 22Ga. wire. I'm gonna practice wind the 3530 and try it out in the E maxx a couple of times first. Get some trial and error testing in so I can make a more educated guess at knowing what the 4130 will do with what wind beforehand.
The flip side to the bigger and longer the stator is, the slower it will go, is the more torque it will have.
The mail lady came today bearing gifts. The Revo Will get the ESC and the BEC, the fan motor cooler is for a Electrifly Ammo 36-56-2600kv inrunner motor that I want to try on the E maxx. I know it's gonna run hot with 20/76 gearing on 4S lipo, but the fan should help.
johnrobholmes
12.07.2007, 04:01 PM
Im ok, I was trying to do windmills on top of an ab ball, fell off backwards and yanked my neck and back. Wish I was still 16 and made of rubber.
On your startup with the DD, when do you call it a good startup? When you can punch it and get instant acceleration every time? I will post pics this evening of my build, seems that it will always start up but the tire size has a lot to do with how fast I can roll into the throttle.
sikeston34m
12.07.2007, 06:51 PM
Instant Acceleration from WOT at any speed is the goal. With the 80amp ESC, I feel like the surge might have been overtaxing. WOT would squeel at anything less than about 5 to 10mph. I know the 80amp ESC was being pushed to it's limits, since If I ran HARD, it would thermal.
Tonight I'm going to install the Monster Pro 125 amp ESC with a 2700uf Cap rated at 25 volts. This is Novak's pick of Caps, so I'm thinking it will be enough.
I got some thermal compound for the base of the ESC. This will insure a really good thermal exchange with the Aluminum Mount.
One thing I noticed with the 80amp ESC, if I had the wheel turned and tried to start from a dead stop, it didn't like that for some reason. Voltage drop from the internal BEC being loaded? Well that's gonna be a thing of the past too. I will install the 10 amp CC BEC as well. This will also remove ESC heat added by the internal BEC.
I also found a neat little micro toggle switch at Radio Shack that I think I will put on the ESC for on/off.
I plan to shorten the motor/esc wires and use the connectors that came with the Monster Pro. They are alot bigger. 5mm I believe and have a higher amp rating.
In light of the problems that plaque the Mamba Max setup, I'm sure the 4mm connectors are barely holding their own in this setup. In fact, if there is any internal arcing going on inside motor connectors, this will make it cog as well.
12.07.2007, 09:13 PM
Do you have a castle link to program the ccbec?
I set mine to 6.5 volts in my revo and am running a 9001 airtronics and a futaba 3050 and neither even get warm with that voltage. Plus the airtronics servo will almost turn the truck if you hold the front wheels still!
You will notoce a big difference eliminating the internal bec on the quark. I have even done it on my 65 roadster and it works well. I have a few $7 CCB (chinese crap becs) and when wired and placed correctly they will work without interference. The ccbec is far superior and only about 3 times the price, a killer deal for a necessary component!
The internal bec just can't keep up with the demands a high torque servo(s) can place on it. They work ok in 10th scale vehicles on 2-3s with medium duty servos, that is about the best you can hope for.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
12.07.2007, 09:24 PM
Hey Sike, I have been away on a small getaway for the past week.... anyways, I was wondering how the direct-drive truck is coming along? Anything new? (being lazy, haven't read the posts)
sikeston34m
12.07.2007, 09:38 PM
Welcome back ZPB! I've missed you man. Hope you had fun on your get away.
Things are going GREAT! I'm at the kitchen table tonight installing some new upgrades.
You need to catch up here. There are some Video's back a page or two.
I'll be shooting some more as soon as things dry up some around here.
sikeston34m
12.07.2007, 09:40 PM
I don't have the Castle Link yet, but I'm happy with the 5.0 volt output. Just as long as I get that extra heat/amp load off the ESC.
The good thing about this is, if I do decide to go with a HV setup, I have the BEC at least.
sikeston34m
12.08.2007, 12:05 AM
Ok, here's the new setup.
1. Quark Monster Pro 125 amp ESC - I added a 2700uf@25volt 105C Low ESR Cap to the power lead. It's a Novak product. It adds plenty of crackle when I plug the batteries in.
Also added is a Micro Toggle Switch. I like it better considering my mounting options.
The motor leads AND the ESC Power leads have been shortened. Also used are the connectors that came with the ESC. They are much larger and more up to the task than the previous 4mm connectors.
A Nice coat of Thermal Heat Sink compound was applied to the ESC before it was strapped in. This should provide the best heat transfer possible to the aluminum mount.
2. CC 10 amp BEC module - This is good for up to 6S Lipo with how it is currently wired.
MetalMan
MetalMan's Avatar
12.08.2007, 01:45 AM
If your theory isn't correct, another one would be that with the wheels fully turned, the front driveshafts are binding a little bit (happens with many trucks/buggies), causing an increased initial load to the motor. As you know, any extra load on startup will not help with cogging.
sikeston34m
12.08.2007, 11:16 AM
Your probably onto something there. I'll have to take a closer look at that.
I was checking it over last night, thought I had a bad wheel bearing. There was alot of slop there. It turned out to be slop in the upper/lower ball joints. They all needed readjusted. All of the slop is gone now.
sikeston34m
12.08.2007, 01:12 PM
This Post is mainly directed at JohnRob since we are both working on doing custom motor winds, so bear with me.
After winding a few stator poles with 4 strands of 22awg @ 5 turns on the 3530, I see this is gonna be tough. It's hard to get it in there and make everything lay neat. Each strand has to behave and lay parallel without crossing any of it's "neighbors".
I think I see now why the person behind the PowerCroco site is going with just one strand. Even though it's stiffer, it should be easier to make lay in the turns and easier to manage.
In researching, I have constantly seen references to copper density, wind resistence, and the effects of not having good values as being "copper losses" Copper Losses result in a motor that runs hotter than normal and one that is less efficient.
To Minimize copper losses, one should have the most amount of copper on each stator pole looking at the Total Cross Sectional Area of the winding. In other words, each stator pole must be as full as possible AND have the least amount of resistence in the wind as possible.
I'm going to try to wind with just one strand to hopefully gain some on this. I'm willing to put out the extra work and effort to do the wind and am not too worried about it "being easy on my fingers" LOL
In order to know what awg of wire to use, first some things must be calculated.
By taking the Cross Sectional Area of a given awg of wire, then multiplying by the number of strands used in an already succesful motor, we should be able to come up with a single strand that is the same as using all those multiple strands.
CSA walks hand in hand with wire resistence also.
Here is a chart that was pulled from the net that shows data for various wire sizes used in motor winding.
http://www.powerstream.com/Wire_Size.htm
30awg Dia. .01(.254mm) Ohms per 1000' 103.2 max. amps .86 Cross Sectional Area = .0000785
28awg Dia. .0113(.287mm) Ohms per 1000' 64.9 max. amps 1.4 CSA = .00010023665 x 20 = .002004733 20 strands @ 5 turns = .010023665 Total CSA
26awg Dia. .0159(.403mm) Ohms per 1000' 40.81 max. amps 2.2
24awg Dia. .0201(.510mm) Ohms per 1000' 25.67 max. amps 3.5
22awg Dia. .0254(.645mm) Ohms per 1000' 16.14 max. amps 7 Cross Sectional Area = .0005064506
20awg Dia. .032(.812mm) Ohms per 1000' 10.15 max. amps 11
18awg Dia. .040(1.02mm) Ohms per 1000' 6.38 max. amps 16
16awg Dia. .050(1.29mm) Ohms per 1000' 4.01 max. amps 22 CSA = .0019625
14awg Dia. .064(1.62mm) Ohms per 1000' 2.52 max. amps 32 CSA = .00321536
12awg Dia. .080(2.05mm) Ohms per 1000' 1.58 max. amps 41
10awg Dia. .101(2.58mm) Ohms per 1000' .99 max. amps 55
Area = (pi) x r2
In English, this formula means "area equals pi times the radius squared." A circle's radius is one half of its diameter, or one half of what you get if you measure all the way across its widest part. "Squaring" something means you multiply it by itself. Pi is a number that roughly equals 3.14159.
A = 3.14 x Radius x Radius Radius = Diameter/2
I have been figuring and adding Cross Sectional Area values to the chart.
The 3530 motor was wound using 20 strands of 28awg wire.
This is a .002004733 Cross Sectional Area of Copper.
14awg wire has a CSA of .00321536
16awg wire has a CSA of .0019625
16awg is ever so slightly less, with 14awg being about 1.5 times that.
I'm going to order some more wire. Copper Density and efficiency can be improved if 14awg will fit. But even if 16awg is used, it will duplicate the density/efficiency scores that are on the market now.
