11.23.2007, 03:33 AM
The only bad thing I can think of is that this converter only allows you to perform the constant-current part of the charge, so you'd be missing the constant-voltage part. The CV stage can add up to between 5-10% of the charge depending on battery type (A123 vs lipo).
brijar
Knowing You're Hooked on RC: Priceless...
brijar's Avatar
11.23.2007, 12:29 PM
Why does it still need a charger to opperate? Does the charger still detect the peak or something, or is it simply a power source? I would like a way to charge more than 3s A123, but the only other chargers I own are a Twin Peak and a Piranha Digital Peak charger, so I couldn't charge them very fast anyway. Could you just use a power supply with the new Losi adapter, or does it not actually terminate the charge of the Lipo/ion when it is done?
Thanx,
Brijar!!!
REVO 3.3 Conversion: 3906 trans, CC 1518, MMM, 6s Gens Ace 5k 40C, LST Diffs, Summit shafts
Slash 2x4 LCG
Two Slash 4x4s
Rustler
