dirt101
dirt101's Avatar
11.30.2007, 04:38 PM
Brian is exactly right
Just to add in I saw a HUGE gain in runtime by going to a 10xl over my 8xl. Yes it is slower but the runtime is worth it for what I do(I just play around in my yard and at local construction sites)
Specs
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Specs - 11.30.2007, 05:04 PM
I think it is obvious that even if a group of people were to race each other with the same truck on the same track that there are a hundred different combinations that can be set up on that one truck, such as gearing, tires, transmission, power (batteries), weight, speed controller, and finally the radio gear.
The only way to have a truly fair compitition is for each vehivle to be set up exactly the same way, such as they do in NASCAR races. Every set up will have different results because they are just not the same. So if we are all looking for the ultimate vehicle and setup with our own vehicle things will always be a little unfair when it comes to competing on the track or in our own backyards and driveways. Our vehicles are as different as we are from each other. Such is life.
