Thread Tools Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
sikeston34m
sikeston34m's Avatar
12.01.2007, 05:25 PM
Originally Posted by johnrobholmes View Post
Just realized I was looking at the wrong motor specs, so the kv would be 604 for an 8Y wind.
That's not a bad place to be IMO. So are you going to go with the Wye termination?
What truck are you planning on going with? The Revo?
I just did another run "test".
4S 10,000mah Lipo yields 52 minutes of pretty hard runtime.
40 minutes into the run, I thermaled the ESC again. This wasn't showing up with the lower capacity batteries. I think this Revo will be getting a Monster Pro for Christmas.
Maybe do a small Cap mod, then attach it to the Aluminum mounting plate with some thermal compound. That should work well for this system.
After the 52 minute run, temps are:
Motor = 125 degrees
ESC = 105 degrees
Batteries = 95 degrees
These Lipo's can give 100 amps continous with 150 amp Bursts. It shows in the performance too. I can tell there's alot less voltage sag under a load, especially compared to the 4000mah Lipo's.
After seeing how things went today with the different voltage levels, I prefer the 4S Lipo Best. With this motor, anything above that, it gets hard to control.
With this setup On 4S Lipo, You will find Nitro parts in it's droppings!
sikeston34m
12.01.2007, 05:45 PM
Hey BL Revo, need to clear some messages out of your box. I can't send you a PM through there.
PM me your email address and I'll send you the videos.
johnrobholmes
johnrobholmes's Avatar
12.01.2007, 09:00 PM
I dont know what I will put it in. The only ride big enough is my x1 CR and I still haven't gotten satisfactory battery trays made up for that one yet. I am going to try a smaller outrunner in a wheely king rig first I think. I messed up the winding on my first try today, and I could fit another strand or two in as well.
12.01.2007, 09:41 PM
i wouldnt get the 125b, it has the same overheating issues that the 80b does, unless you do the mod, but that voids your warranty.
sikeston34m
12.01.2007, 10:12 PM
I'm pushing alot of power through the 80b, and I know there is some seperation from the heat sink inside. I've had it apart a bunch of times.
The Monster Pro 125 has a higher rating because it has more FET's on the power card. This also means less resistence, so more power flow.
I really like the Quark line, mods or no mods.
johnrobholmes
12.02.2007, 08:53 AM
I switched to 5 strands of 22 awg wire. Crikey it is hard to wind tight! Took more than an hour for one phase of the motor, only 2 left. With all this work I will leave all 6 ends open so I can switch from D to Y termination on the fly. Just so happens that a 8D on 3s is almost exactly the same rpm as an 8Y on 5s (wattage should be the same too). Time to test this kv VS startup torque thing.
sikeston34m
12.02.2007, 05:42 PM
I've been doing some more research about this on my own.
Delta has 1.72 times the kv as Wye Termination but draws 1.72 times the amps.
Wye has 1.72 times the torque as Delta, but draws 1.72 times less amps.
SO, correct me if I'm wrong, but to make the Wye termination put out the same wattage and KV, You must use 1.72 less winds on the stator.
There are two big advantages of the Wye termination IMO.
1. More Torque! 1.72 times as much torque. I think this is mainly due to the fact that 8 magnets/poles are in use at any given time, rather than 4 magnets/poles on the Delta.
2. More EFM feedback to the ESC at lower rpm's. I just discovered this today as I was reading about this. The Wye should run/start MUCH better in a Car/Truck Application.
I'm thinking about taking a short cut to the entire winding/experimenting thing. AXI motors says "If you have a custom motor in mind, do not hesitate to contact us."
I think I'm going to ask them if they can do a custom wind for me. I want a 4130/8 with a Wye Termination. I want to shoot for 700kv and with a Wye Termination, this should be a BEAST!
