BlackedOutREVO
12.03.2007, 03:35 PM
A NEU 1509 1Y (3600KV) Is what I was recommended by Mike , Mike even has them in the store....
And then theres a lower KV NEU in there, which would probably be a better 4s motor.... The 3600 KV Mike told me to get was to run 2 and 3s....
Im sure the LMT 1920 would work, but I think a 1930, or the NEU 1509 would be better...
ncalenda
Need for Speed
ncalenda's Avatar
12.03.2007, 03:58 PM
If you use this motor, what pinions will work? Isn't the shaft a different size?
  Send a message via AIM to ncalenda
BlackedOutREVO
12.03.2007, 04:12 PM
No, it has a 5mm shaft..... You wont need a bore reducer
