I have been trying to get these thing shimmed for days! #@/!* I can't seem to get them. One works perfect. The other one though is a real pain.
Renée, I tried your suggestion however now the pinion is binding. Does anyone have suggestions for me? Out of desperation last night I sent Mike an e-mail asking if he would put them together for me. Do I feel I like a noob.
This may sound dumb, but have you removed the bearing on the ring gear side and check to make sure some dirt, etc is not making it stand away from the ring gear? Or maybe swap the bearings side to side and see of that helps. If your ring and pinion are binding it means that something is pushing the diff over towards the pinion. Are you using hb diffs?
