Green machine.... For gear ratios, I believe 18/66 is stock, so probably work from there with those 600 can motors- probably get away with larger pinions though I bet.
mike has 12t to 25t mod1 pinions here - and depending on the shaft size of those motors, you would probably need the bore reducer as well with each pinion.
