B15
12.17.2007, 10:47 PM
Im using stock Jato hub carriers with 6x11 and 6x15 bearings, and some aluminum arms meant for a jato.
Heres some really old pics, but they show what Ive done pretty well:
Youre using RPM rear arms right? Youre probably going to want aluminum with the big rear tires. The arm flex will cause pretty bad wheel hop. The stock jato arms did anyway.
I wouldnt discount the integy adapters already, the maxx wheels will have a lot less offset than wheels meant for a rustler so the center of the contact patch wont be too much further out. It looks like the shorter 2 hubs with the zero off set wheels would be about perfect. With my 1/2" offset wheels and jato arms, the inside of the tires barely clears the outer edge of the body, and I had to trim the fender wells some to make it work. The body is a desert rat meant for a maxx, rustler bodies look stupid on this thing now. My rustler is longer and wider than my 1/8 buggy.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
12.17.2007, 11:47 PM
More Jato stuff huh? Are the Jato diff output shafts 5mm? I ask because I saw this MIP Jato CVD kit. Or do you think I can use the MIP Rustler drive cups I already have? I guess the ball on the end of the CVD would need to be the same diameter. If this would all work I'll get the RPM rear arms and the stock Traxxas stub axle carriers. I like the plastic for the weight savings. If it has issues I can upgrade to aluminum later. Did you use the stock length camber links?
