sikeston34m
sikeston34m's Avatar
12.21.2007, 09:16 PM
Originally Posted by ilpufxit View Post
So I just brought my meter home and tested the motor. No continuity to the case on any wire. All three wires have continuity to each other. I even tried spinning the rotor with the meter on just in case.
This motor will run if you spin it up gradually but the heat build up happens too fast to even try to actually drive it.
I've heard that it can be difficult to get these fixed. Is there any (more) local alternative for repairs?
My connectors are the standard 4mm bullets compatible with MM
No continuity to the case it good!
You will always have continuity between the motor wires. It's a 3 phase winding, so if you don't have continuity between them all, something would be wrong.
Hmmmm........let me know if you find anything with the connectors
