Patrick
Patrick's Avatar
01.02.2008, 10:17 AM
You only need a little bit of grease in the e-maxx tranny, no problem with leakage. I've heard of people running them dry as well.
david lamontagn
01.02.2008, 11:03 AM
Yes i use grease too in my revo trany, but in his E bay post, he tell that he use Lucas oil treatment, and this thing is like oil, so i suppose taht he have make speciale seal on the tranny halve case and on the bearing output shaft to keep oil in
Patrick
Patrick's Avatar
01.02.2008, 11:05 AM
Oh, ok. I'm not sure then.
01.02.2008, 11:26 AM
He uses sealed bearings to keep the oil stabilizer in. That stuff is thick, like gear oil, so the sealed bearings should keep it in.
david lamontagn
01.02.2008, 11:44 AM
No sure, because between the bearing and housing, it's not 100% oilproof. And for the two tranny case halve, this stuff can leak there too.
