squeeforever
squeeforever's Avatar
01.02.2008, 03:49 PM
Serum, did you use traction compound on the tires?
Personally, I would go for something like a 6S1P Flightpower pack (no idea if it will fit though) with one of the 6S capable MGM ESCs and a Neu 1512 1.5y/F.
Differential Ratio: 1
Transmission Ratio: 2.2727
Other Ratio: 1
Spur Tooth Count: 45
Pinion Tooth Count: 19
Total Voltage: 23.4
Motor KV: 1900
Tire Diameter (inches): 2.874
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.009
Spur/Pinion Ratio: 2.37 : 1
Total Ratio: 5.38271 : 1
Tire Circumference (inches): 9.03 inches (229.34mm)
Total Motor Speed: 44460 RPM
Vehicle Speed: 70.62 MPH (113.44km/h)
Effective Speed Rate: 3.02mph/V (4.85kmh/V)
Effective KV Value: 1900
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
