I would suggest ressetting the esc and radio- cutting out at full throttle sounds like the EPA is too high ( the novak esc doesnt like 140%- turn it back down to 100% if you have that function). Also make sure the radio trimm is set to neutral before reprogramming the esc. If that fails to solve te problem, then the esc is most likely toasted saddly. Were you using the 4.5 motor with the esc that died?
