DrKnow65
DrKnow65's Avatar
01.12.2008, 07:23 PM
Yes, the newest version. Are there more than 3 generations, or less?
GriffinRU
01.12.2008, 07:37 PM
I've seen 4 variations so far...
Sweet. Assuming it all still works fine once the brain is reconnected to the/a powerboard, you would need to use a seperate LVC to protect your lipos (since the built-in one is turned off)? That was what I was getting at before really. You never cease to amaze me with your electrical wizardry....
I've tested 2 modified controllers with 6S for 30 minutes, running up/down/brakes with no problems. Have not tested unmoded ones.
MM mods
ilpufxit
ilpufxit's Avatar
MM mods - 01.12.2008, 08:22 PM
I just sent one of my MM esc's in for mods. I'm hoping to run 5s in a 1/8 buggy when I get it back. Does that seem realistic? Reliable? I'm running it now on 4s with an un-modded MM and so far no problems. I was running an 18t pinion and it got pretty warm after 8-10 min really heavy bashing, didn't thermal though. I switched to 14t and there's very little heat.
