austinmaxx
01.14.2008, 04:11 PM
Probably I have (2) 8000mah 7.4 2s maxamp lipos and they fit easily and I have to use the little foam spacer they give you for running 6cell packs and there is room for heavy moddding for longer packs if it is needed....I must say it might be alot of weight with that much battery size...do you need that big a batt?
speedy
01.14.2008, 06:42 PM
The two 12000mah 2s packs weights the same as 14 4500mah + nimh cells but will give me like 60min + runtime and i think that woud be great :)
