JeffEmbracedDC
JeffEmbracedDC's Avatar
01.23.2008, 05:11 AM
So.. I found an RC10T in my garage.. and decided that was good enough reason to buy a sidewinder :) Got it on the way Priority along with a few 10T parts. Yipee! Also ordered some stuff from Mike for my 8ight :) should post some photos in a week or two!
-Jeff
BL 8ight, BL FT B44, BL FT TC4, BL FT T4
  Send a message via Yahoo to JeffEmbracedDC Send a message via AIM to JeffEmbracedDC Send a message via MSN to JeffEmbracedDC
cart213
cart213's Avatar
02.23.2008, 01:42 AM
What battery will you be using? The 4600 should be ok with 3s lipos, but the 5700 would be better for 2s lipos.
FG101C
02.23.2008, 01:44 AM
Yeah I forgot to mention I will most likely use the MaxAmps 2s 5000mah.
neweuser
neweuser's Avatar
02.25.2008, 10:13 AM
You could go with the 5700, but if you ever want to go 3s, I would get the 4600. 4600 is more efficient. You could gear the 4600 up a bit too.
FG101C
02.27.2008, 09:10 PM
Just got my Sidewinder 5700 combo. In Castle's manual and on the sticker on the motor it says 3S Lipo max. Guess it can handle 3S LiPo's.?
cart213
cart213's Avatar
02.27.2008, 09:25 PM
The motor can handle 3s lipos, but the Sidewinder is not designed to handle a 5700 on 3s. The current draw will be too much.
FG101C
02.28.2008, 12:01 AM
Ok, I see it now.
neweuser
neweuser's Avatar
02.28.2008, 09:58 AM
I think the sidewinder can handle 3s, I would make sure to use a bec though just in case. Take for example the MM esc, can take more than specified.
