80 amp MGM esc
80 amp MGM esc - 01.17.2008, 02:01 PM
Will this esc only work w/ 4 pole motors?
01.17.2008, 02:25 PM
I believe MGM are fine with motors with more that 2 poles...
neweuser
neweuser's Avatar
01.17.2008, 02:36 PM
It should be fine on 2 pole as well.
01.17.2008, 04:01 PM
So if I am correct the mgm will work w/ the Feigao 8xl
neweuser
neweuser's Avatar
01.17.2008, 05:01 PM
Indeed.
wallot
wallot's Avatar
01.17.2008, 04:28 PM
feigao is 2poler and mgm will work with as well with 4polers like neu or pletty
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
01.17.2008, 05:00 PM
because of the 8xl, would I be better off w/ the 80 amp or 120 esc/ I won't be using more than 4s
neweuser
neweuser's Avatar
01.17.2008, 05:06 PM
The 80amp should be fine. But if you want a tad more security, and may update your batts later, then get a tad bit bigger esc, it will never hurt having a higher end esc.
