Revoman
01.17.2008, 03:09 PM
based on that im looking for, i want a neu 1515 1y with a TrueRC 22.2V 6S2P 8000mAh. that will run at 48k rpms which is fine so everything should be good correct? its only 8 ounces heavier than the 5s2p battery......ill be using the MGM 16018 controller so based on the specs everything should run good. anything im missing?
bah got to thinkin itll run hotter and have less run time correct?
i want a good bit of runtime so going with the 6s would make the run time shorter?
