lutach
lutach's Avatar
01.21.2008, 05:30 PM
Originally Posted by Sower View Post
Why is it that on that thread Patrick is really good about giving info out and then he just vanishes? His last post was on Nov. 15th - that's two months without any updates . . . ? Seems like there's a problem to me.
A company like Castle should not have any problems coming out with good ESC. My best guess is that they are trying to make their controllers different from others and stuffing a lot of things that is not needed. One example is the timing, Castles doesn't use the usual degrees like most companies do and that will confuse some people. I know that 2 pole motors works good with 0-5 degrees in timing and I've seen in another forum a guy that used to work for Castle recommend 18.75 degrees with the GT on 2 pole motors. I know from my experience so far if I set my controllers with a higher degree of timing on 2 pole motors, they tend to overheat a bit. I like MGM's Automatic setting .
