orangecrush
01.28.2008, 11:35 AM
An update.... I installed the stock receiver and it gave me the same response....
That was until I tried what happened to member GYN77. He had the same problem until he pushed lever forward instead of backwards. It now allows me to enter programming mode.
Jerry, I will cover those up as soon as I know it works. The wires are definitely separated for now and I would never run it that way, I just want to make sure I don't have to disconnect the unit to send it back in.
I will check up on how to enter each mode using the transmitter.
Mark
Later update....FRIED.
orangecrush
Later update....FRIED. - 01.28.2008, 03:52 PM
I got through the programming stage. It took me several attempts but I finally got through it.
After the programming, I shut everything off and went back into the programming mode so I could change the first parameter to automatic tuning as per Mike but when I tried to use it later, it shuddered and stopped.
No more beeps, no more nothing.
I overnighted it back to Mike to let him look at it. So far, it's not looking good.
Mark
