MetalMan
MetalMan's Avatar
01.29.2008, 11:26 PM
Like bdebde said, countersink bit to make countersunk holes. I use 1/4" for 3mm screws and 3/8" for 4mm screws, and adjust the depth to make sure the screw heads aren't above the surface.
To make slots, I use a drill bit to make the inital hole, and then a scroll saw to cut out the slot.
