1986camaro
02.02.2008, 01:29 PM
does weight matter with the torque of the motors?
02.02.2008, 02:25 PM
Direct soldering is a good idea, it eliminates the connectors, which can cause problems.
If you have a motor that is undersized for the weight of the truck it will have to work too hard and will get quite hot. Generally a larger motor will stay cooler longer.
1986camaro
02.02.2008, 06:56 PM
the truck with batteries weighs 10lbs flat.
