Takedown
WARNING: May become violent.
Takedown's Avatar
02.07.2008, 10:07 PM
You forgot that you are on the RCM forum. The peeps here are brushless experts.
I guess... I still wouldnt use Castle motors if your going for all out insanity.
snellemin
2 KiloWatt RACER
snellemin's Avatar
02.07.2008, 10:32 PM
But you are only seeing one part of the use for the motor. If the load is light enough heat won't be that much of an issue.
Last year the cheapo Mamba motors were used to break the 100mph barrier in 132 feet. I consider that all out insanity.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
speedracer1129
02.07.2008, 10:51 PM
All I can say is that unless you have extensive knowledge on figuring out your load calcs for your car, then stick to the manufacturers recommendations. These motors are very capable for the money. However, you do have to know what your limits are or you can blow alot of money real quick!!
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
02.08.2008, 07:46 PM
Where did you here that. That sounded like what happened to another setup. I heard the 4s setup w/ the hv4.5 ran all day without major problems.
Area 52 Ranch Raceway
T.R.C.R.
speedracer1129
02.10.2008, 09:21 PM
From my understanding from some of the guys from the high-speed forums, there was more to the story......
Regardless, I am having zero problems so far with my MM setup.
