rchippie
rchippie's Avatar
02.04.2008, 07:17 PM
Will the maxamps 2s2p 4200 fit under the stock strap that comes with the extended crt.5 kit from mike. My 2s2p 8000 is a little to heavy for this truck in my opinion plus it wont fit under the stock strap. .
REAL MEN RUN BRUSHLESS
GO-RIDE.com
02.04.2008, 08:03 PM
Those are the batts I just got for my crt.5 makeover. They fit in the stock RCM batt holder. I run 1 set of the batt post spacers and velcro. The truck handles a lot better than when I had 4800 hard packs. I moved all the electronics to the chassis and the radio to the top of the steering servo.
Those are nice batts. Lots of punch and runtime for only 225gm. I use a Novak GTB esc and Novak Velocity 6.5 motor.
E-8ight - Tekin RX8 2000kv/4S
rchippie
rchippie's Avatar
02.04.2008, 08:21 PM
Thats good to hear because i just ordered a 2s2p 4200 from them . I had a 25% discount from them when my 2s2p 8000 puffed. so the total was $80.43 with 12g upgrade & priorty shipping.
02.04.2008, 11:12 PM
That is light battery, you should have a really good handling .5 when you are done.
What motor are you going to use? Will you step down to the feigao 8s or are you going to try a different mfg motor? Any specific kv, or are you looking for a less powerful motor? Just curious!
rchippie
rchippie's Avatar
02.05.2008, 07:53 PM
James im using the 7s -5070kv on i got from you. Do you think it will be okay with the truck tires ?.
02.11.2008, 08:38 PM
I really do not see any reason that the 7s would not work. You will have to lower the gearing due to the taller tires to maintain the same speed. I would say to try it and keep checking your temps. The s can motors are pretty good motors, you could step up to a l can, or go to 3s but both will increase weight.
