jhautz
jhautz's Avatar
02.08.2008, 10:40 AM
Originally Posted by mkrusedc View Post
Get the two cables mentioned in post #2 and it will be as easy to program as an MM.
He would still need to set the throttle positions with the radio which is all he is trying to do right now. The cables wont help with that.
patx - check to make sure the epa on your radio is adjusted as high as it will go on both ends (throttle and brake). If you dont get enough travel the esc might not be recogizing it.
to make it...
or break it...
Silent...But Deadly
mkrusedc
NeuMaxx
mkrusedc's Avatar
02.08.2008, 01:20 PM
Sorry, I never had that problem with mine. I pluged right up set batts, cutoff and freewheel and was ready to roll.
