GriffinRU
02.08.2008, 01:11 PM
Originally Posted by MetalMan View Post
Just to clarify, you have attached the switch negative wire to the blue wire? Have you done much testing with this setup already (like on 6s, to test reliability)?
Yes, that is correct.
I've tested it last week on the bench, right at this moment I am testing on E-Maxx.
Give me half an hour and I will update with real test info.
DON't TRY this setup!!!
GriffinRU
DON't TRY this setup!!! - 02.08.2008, 01:24 PM
I encounted serious problems with this setup, not quite sure why. But I do need to investigate, it cogs like crazy at mid to high RPM...
Sorry, update will follow.
