Don't solder on the circuit board
Bernie Wolfard
Clinically Inane
Bernie Wolfard's Avatar
Exclamation Don't solder on the circuit board - 02.08.2008, 01:28 PM
Please do not solder on the circuit board as it voids the warranty. Before you all post things like "I am a pro solderer" and "I have soldered on circuit boards all my life and really, really, really know what I am doing" consider this. We use high temperature, lead free solder with special flux to enable us to sell our products into the European Union. This solder and flux is not readily available. The circuit boards are heavy copper and conduct heat very well. The problems these create are that standard lead based solder does not mix well with our solder and will create a cold joint. The amount of heat it takes to flow our solder is conducted though the circuit board to the point where parts will loosen or fall off the other side. It takes special training and equipment to reliable solder onto a Castle Creations circuit board without creating problems. Because of these issues, we do not make exceptions to the rule that if you solder on the circuit board the warranty is void.
If you really feel you need to solder directly onto a Castle Creations circuit board and later have problems the saving grace is it only costs about one third to one half the cost of a new ESC to have it replaced. Check the out of warranty replacement costs on the ‘Support’ tab on our website, www.castlecreations.com.
Bernie
