4 of the 8 stops are held in place with 2k glue, and the other two (length) can be hold in place by a lexan 1.5 mm thick sheet, that presses the plates in, and lays under the battery to press them tight in place.
it would be an option to make the braces from aluminum and use button head screws to hold them in place.
It would be fair cheap to produce if you have them laser cut.
