02.11.2008, 04:02 PM
Yes, just don't use the steering servo at all if for a short time. It's the current draw coupled with a high differential voltage that heats them up.
miniGranis
02.11.2008, 04:06 PM
I guess unplugging the steeringservo would make if "safe" when.
As I said I only need to test / arm the MM.
BTW I might be stupid here, can I test the MM with Feigao on 2S ? (I do use 2S in serial normally)
