pipeous
5th Scale Guy
pipeous's Avatar
02.11.2008, 06:55 PM
I got this from one of the guys that has been racing his converted RC8 and though I'd share.... I didn't know RCPD made a battery tray for the RC8!!
im gonna save you some hassle
while its sittn there lookin preety.. go over everything.. front and rear diffs... all the nuts with a lil dab of ca glue.. mainly the ones under the wing unter the top plate.. and the ones that hold the shock tower on.. this makes changing anything a breeze and you dont have to worry about the locknuts falling out.. ..
secondly go into the center diff.. put an additional shim behind the four lil gears. and if your using a kyosho spur take the two shims that suppsoed to be under there and put the spare one. (since you can only use one on that side ) under the other sun gear.. refill with 7000 weight diff fluid..
if you dont do this to the center gear your gonna eat innards like crazy.. the stock center diff setup is shimmed loosely
