DickyT
02.11.2008, 07:51 PM
15 min run, much better with the CD. it doesn't unload but still has enough give in the fluid that it functions. that ofna diff lock lube is the stickiest stuff I have ever been around honey to the 10th power. lol
I went out:
12 old nimh
mm settings:
Punch control: 50%
motor timing: normal
brake: 45%
1st bar on throttle curve raised to 10%
all other settings at default
14 minutes of dead starts and hard stops and hard corners under power (still under powered) and the fronts showed zero signs of ballooning and it certainly has not lost any handling, amazingly no cogging, even with the crap batteries. castle nailed it with this last update.
I have the suspension pretty dialed in right now, but that will all have to be readjusted when the lipos arrive.
Thank you everyone who has helped me get my 1st conversion drivable. Special notes to Serum and BrianG, I could not have done it with out you guys! . Here's looking forward to project completion. :D
DT
