sikeston34m
sikeston34m's Avatar
02.12.2008, 04:59 AM
Just saw the other thread with Mike's custom center diff that has the slipper built in. That looks perfect for this conversion. I will wait and see what size spur it has and then buy the motor. I think that the 1400kv motor will be fine with the quark esc, even with the high pole count and motor rpm. Does quark spec max rpm with various pole motors? I do not remember seeing that info, but have never specifically looked for it.
There are much cheaper ESC's that boast such max rpm figures as 210000rpm (2 poles), 70,000rpm (6poles), 35,000rpm (12 poles).
I really don't see the Quark's switching ability has being a problem.
The max. rpm of 25,000 on 5S is also being figured unloaded isn't it? I doubt the motor will ever hit that unless you're jumping at WOT.
02.12.2008, 11:15 AM
I did not think it would have issues either. WOT jumping, that sounds like fun, and flipping and tumbling. And most likely some broken parts! HAHA
