MetalMan
MetalMan's Avatar
02.13.2008, 04:46 PM
Originally Posted by magudaman View Post
Isn't horsepower a unit of power and torque is just force. We can convert HP into watts but not torque to watts. Heck I can put a bolt on at 150 FT/lbs but can't move it at that rate more than 1/8 rpm so my horse power is very low. It is is two different types of measurement, thats why you need both.
Torque = force x distance (it's ft-lbs, not ft/lbs, lbs is a unit of force)
Torque can be converted to watts if there is a specified time over which that torque operates.
nativepaul
nativepaul's Avatar
02.13.2008, 05:48 PM
1. What KV is a faster motor. a 3500kv or an 8000kv motor?
2. When an esc is rated for 6S, does this mean two 3 cell batteries, or does it mean two 6 cell batteries?
3. Can you run 2 brushless motors on the same spur gear and gain twice the speed, or is there a slight gain with 2 brushless motors?
4. Are there faster and better RC Brushless electronics than Novak, and LRP?
5. Can Lipo batteries explode with out proper balancing?
1. 3500kv, a lower KV motor will handle more volts before it exceeds its max RPM and the stator explodes.
2. could be either 2x 3cell packs in either series or parallel or 2x 6cell packs in parallel but not in series.
3. no, running 2 motors on the same ger ratio will not increase your top speed at all, you will increase the torque but you need to gear up to use that extra torque to raise the top speed.
4. Yes
5. overcharging a LiPo can make it catch fire whether a balancer is used or not, a balancer means all cells should catch fire at the same time tho.
Xray XT8, 1518, MMM, 4s5Ah.
Lots of boats.
fastelectrics.net
