orangecrush
02.14.2008, 07:43 AM
Did you set the esc to the radio before programming with the pc?
I made sure the receiver was binded with the new transmitter.
Then I went into programming mode using the transmitter and set the end points for full forward and full backward.
Is that what you meant?
Thanks,
Mark
bdebde
That's All Folks!
bdebde's Avatar
02.14.2008, 10:46 AM
Thanks,
Mark
Yes that is what I meant.
Were you able to hold full throttle for several seconds while doing the autotune? I never ran the autotune on mine because I never had the space to hold full throttle for several seconds around the house/yard. I also had trouble getting it to run when setting autotune from the software (try doing it with radio). Try resetting the controller to defaults and start over (endpoints too), if you can't get the autotune to work, don't use it.
lutach
lutach's Avatar
02.14.2008, 11:29 AM
Is it possible to do the Autotune with the vehicle off the ground or does the vehicle have to be on the ground so it sees the load?
bdebde
That's All Folks!
bdebde's Avatar
02.14.2008, 11:39 AM
I think it needs to see the load.
