sikeston34m
sikeston34m's Avatar
02.24.2008, 10:34 PM
Well, from my extremly limited knowledge, the brain has to have some sort of regulated voltage. An opto isolated esc does not have the current ability of a bec built it, but must have some sort of regulated supply for the brain. Time for the smart people to tell you what to do.
How about I eliminate the onboard bec, then just feed the Brain "through" the red wire from the external bec?
Sounds like I would have to keep the external BEC set at 5 volts though.
Hmmmmm..........
02.24.2008, 10:57 PM
Hmmmmm..........
Sounds like it could work. However I would consult Griffin first to see what he thinks!
lutach
lutach's Avatar
02.24.2008, 11:11 PM
I'm not 100% sure, but I think you can. Here is a picure of an OPTO Hacker controller (http://www.rc-monster.com/forum/atta...2&d=1202243485) and you can see 3 silver spot where usually those components would be. Probably tomorrow I will send Artur my Hacker and the other ESC to see if he can swap MCUs. Sikeston, can you post the number on the driver and what that symbol is? Also, what is the part number on the MCU? It looks very much like a Silicon Labs.
sikeston34m
02.24.2008, 11:51 PM
This is some really tiny stuff. This Camera can see better than I can. LOL
I hope this helps.
lutach
lutach's Avatar
02.25.2008, 12:35 AM
I hope this helps.
Nice. Thank you.
