bdebde
That's All Folks!
bdebde's Avatar
02.26.2008, 11:56 AM
How much ground clearance do you get (or gain) with that set up? I was thinking of trying the super rs4 tires on my rs4.
lutach
lutach's Avatar
02.26.2008, 03:23 PM
I got a 6mm gain. With the normal wheel/tire combo it was 5mm and now it's 11mm. The foams for the Super RS4 is a bit taller than the slick on the car now.
lutach
lutach's Avatar
02.26.2008, 07:15 PM
I was going with the Hacker B50-6S, but it was just too fast so I decided to go with the B50-8S. I just finished adjusting 2-speed. The VXL ESC seems to be working good with the Hacker.
lutach
lutach's Avatar
02.26.2008, 08:18 PM
RS4 2-Speed going back in the basement. I have no clue what went wrong, but second gear fried. Everything was going good with the adjustments, but after I mounted the ESC, battery and receiver, I hooked the ESC to the motor gave it some throttle and found that some how the second speed spur gear was bent. Now I can't even take ot the clutch as the system doesn't move like before.
