02.26.2008, 02:13 PM
Actually, I always speak in rms terms. And it is better to run a higher power amp than the sub can technically handle because of the duty cycle of the signal; where you only run max rms power for about 10% of the time, and MUCH lower power on average. For movies or any other dynamic media, you want some headroom. If you are running 200w to the sub during normal listening, then a car explosion hits, the sub will want more power for that time then the amp can deliver and will clip. It's much healthier for the sub to see clean power than dirty clipped power.
02.26.2008, 02:32 PM
ya thats what i thought.
it just makes more sence to me.
02.27.2008, 12:24 AM
well.... then..... If you are going to run two 12" car subs off a plate amp there is something you need to consider, speaker impedance. Most car subs are 4 ohm impedance, but some are 2, 8, 6, or even dual voice coil models which have two impedance values. It should say, "4 ohm" or something similar on the magnet of the woofer. Lets assume they are both 4 ohm subs- you can either wire them in series for an 8 ohm load, or in parallelfor a 2 ohm load. Those are your options for wiring 2 subs to a single channel plate amp. Most home audio amps are rated at 8 ohms, so the 8 ohm in series example would work, but a 500 watt rms amp would only give 250 watts to each sub, power is split equally. A 2 channel amp rated for 4 ohm operation would also work, I just thought you should keep this in mind when selecting an amplifier.
02.27.2008, 10:35 AM
hmmmmm... well.
idk what im going to do yet. i guess ill see how it goes when i get my 12 hitting harder.
also i was thinking right now...
how do i connect the sub to run at the same speed/time or w/e as all the other speakers? since it is being ran by a separate unit how would i do that?
02.27.2008, 12:25 PM
Originally Posted by t-maxxracer32
hmmmmm... well.
When I first read your post on setting up three subs, that was my number one concern. Yes, you'll have bass up the wazzzooo, but its all going to be out of phase and sound like crap unless you have crossovers (do plate amps have these built in?). If they dont, then you need to purchase them, and add them to the circuit. For your front subs - you can purchase a RCA "sub splitter jack" - basically allows for one in and two out. Run your sub out to it, then individual RCA's to each sub. (my M&K has "networking" built in for running subs in series or parrallel?) For the rear surround sub - I'd look for a plate amp that allows you to run both your R and L surround speaker wires into it, and has sub out, and R/L audio out. I dont have a clue if they even make such a thing, but in that scenario, your sub would be carrying the low bass for both the surrounds.
02.27.2008, 12:41 PM
whoa, whoa, whoa, we're talking about a sony reciever in a "hang out" room here, not a stack of krell components in a classical music playing reference system. Unless he mixes up red for black the speakers wont be out of phase, a crossover would be nice, but he just wants more boom. I think he's on the right track and as his audio taste and knowledge grows, maybe then we can get into crossovers and timbre matching and speaker placement, but for a boombox in a gameroom how in depth do we have to get? I guess we should ask t-maxxracer. Hey t-maxxracer- do you want the best of the best in an audiophile style system, or do you just want more boom for you room? The sky is the limit when it comes to audio, makes r/c's seem cheap, I do miss my denon/b&w/martin logan home theatre setup, but the $10,000 was better used elsewhere!
02.27.2008, 01:08 PM
Actually, multiple subs that are not colocated will not be in phase at the listening position.
| Thread Tools |
| Display Modes |
Rate This Thread |
Hybrid Mode
