Sammus
Sammus's Avatar
02.27.2008, 09:42 PM
Originally Posted by Hickoryhead View Post
And of course paraelle gives you double the run time and series gives you double the power output.
Close, theoretically series gives you double voltage with the same potential current draw, parallel gives you the same voltage with twice the potential current draw - so the power is really the same, just in different forms :)
But for what it's worth, higher voltage is generally more efficient than high current, so it is better :P just being my pedantic self...
Jbreddawg
Jbreddawg's Avatar
02.27.2008, 10:57 PM
I really appreiate the great advice ! I was just using those as an example, i have enough money invested why cheap out now !! i do plan on getting good batts, i used to race along time ago and the quality batts made hugh differences !! I was just wondering if I could go with less mah but as i see now that will also hurt the output capability . thanks again for the teachings !! Jerry
p.s. my gorillamax G2R chassis and rc-monster motor mount showed up today !! And I purchased "dont tell the girlfriend" another roller to continue on with my own custom chassis build !!
