02.29.2008, 03:57 PM
Originally Posted by 83gt
Isn't that 100% dependent on motor KV ? If the motor KV is low enough to get into a good motor RPM range with 5s or 6s, then you are MUCH more efficient than similar speeds on a 4s setup.
I'm not sure If i'd be interested in an HV quark or not. My experience with the 125b's has been less than favorable. My MM is just about as nice a performer, at 1/2 the size, and 1/2 the cost. I love my smaller quarks, but the 125b is just a disappointment to me. I suppose you guys could try it out first, and if it beats out the MGM and MMM then I might give it a shot, lol.
J.
That's true, but My 1700kv 1515/2.5 blows the tires off on my track on 5s. I know KV determines speed, it also determines torque and power. The higher the overall power and efficiency, the motor likely there will be at least traction problems, broken parts at most
03.01.2008, 12:50 AM
I don't think the 1515 2.5D on 5s is too much for the track. With the gearing I usually use (46/12) it has less top end than almost all the other 4s truggies I race against. Even when I did some practice laps on 6s with it and 46/13 gearing it was very fast, but still controllable. And how much you spin the wheels just depends on how you drive.
03.01.2008, 09:28 AM
I will by Quark, just because it is different for around half the price of 125B, because IC's now days are getting cheaper and they already good for CE and RoHS.
As for design flaws, I can pass them couple thoughts if they contact. But in general I am not happy with pcb layout they have, from heat transfer stand point. Enclosure (case) can be improved but pcb is the culprit. Also, make it water proof, so simple with silicon wires...
03.01.2008, 11:01 AM
When I first saw the 125B, I was a little freaked out as the positive and negative power wires came out ot the same place. When it burned and I opened the case to see what had gone wrong, you could see that the problem might have started there. I like ESC that places the power wires at the corners. Like the ones I'm having made and the one Artur made. If my controllers gets done soon, it will be the first of it's kind just for cars. That would be too funny considering that the big players all have HV, but they are for aircraft. I have no clue why we haven't seen a HV controller for cars yet. To me all this companies are too greedy and only thinking about what the returns might be. Off topic: A lot of people are pissed of at a few Asian companies for pricing the products right (In my opinion). You can buy hard cased 3200mAh 7.4v lipo for $34.99 (used to be $49 which still is cheap). They use the same concept I use and when my controllers gets done, I will also use the same concept.
03.04.2008, 11:58 AM
Hi, I saw the video footage of your daughter. She is lovely, and you must be very proud of her.
I think you have a lot of things to say about Quark Monster Pro 125B. Can I ask you to be more specific about the strengths and weaknesses about that particular ESC? I personally agree with you on that ESC having the + and - power wires coming out of the same place. And I think Quark should have made the case differently, so that it gets cooled more easily. Please let share your thoughts with me. Thank you ^^
03.04.2008, 12:26 PM
Thank you. She is my life.
I'm trying to have a HV controller made. The engineer was going to do a 200A capable of 14S lipos, but he used sample boards that did not handle the AMPs. So I asked him to do a 60A, 80A and 100A. I like HV (12-14S) as it helps keep the temps down. I've talked other companies about this and they make it sound impossible to do. I'm not an angineer, but I know it's possible as I have a Schulze 40.160 (14S lipos), Actonic120 (12S lipos) controller that has car mode. The problem is that most companies want to make things smaller and smaller, but then they say hardware is not compatible. Kontronik did a fantastic job with the Jazz 55-10-32 as it has a car mode. It is small and freakish powerfull. I only hoped Kontronik would make the Power Jazz that way as well. There are very good MOSFETs out there and they need to focus more attention on them. I like the MOSFET found in my HW and I know Cyclone will have a controller with the same MOSFET. The SHV from Castle also uses them. Most people should realize that with HV you won't need 200A. You can still use 4S, 6S, 8S or 10S lipos if you want. You will be able to go out and buy a smaller capacity pack at a great price. The way some controllers are built though, you can still have a controller put out 200 or more AMPs for the bursts. Keep in mind, in order to get power from a 6S set up you will need more AMPs (22.2V x 200A=4440 assuming your batteries can put out that much AMPs), with 10S set up (37V x 120A=4440 now a good 5000mAh pack will do that), with a 12S set up (44.4V x 100A=4440 that's better) and with 14S set up (51.8V x 85.71A=4440). Now 4440W is a lot of watts. Most people are happy with 1400 to a little over 2000 watts and if you devide 2000W/44.4V you will need 45A to get it and 2000W/22.2 will bring that number up to 90A. Kontronik, Schulze and Actronic are the only companies with good HV (real HV not 22.2 volts) car ESC. I apologize for the long post, but I like HV  .
Edit: Also, a lower Kv motor tends to make more torque then a higher Kv motor does and one advantage of a electric motor is, powr from torque.
RC carbon junkie
Fried Quark Monster Pro 125B -
03.04.2008, 06:29 PM
So do you think that the positive and negative shorted this out?It does seem to have started at the power wire end.This almost toasted my truck.I am very bummed to be out 275 bucks and no reply from quark.I have run the same Neu 1515/1.5D/F 14.8v in my MM holemod.I had to almost rip the top off my Losi 8t to yank the ESC out when it fried.The power terminals melted off the ESC.
03.04.2008, 06:46 PM
That is a familiar site  .
RC carbon junkie
03.18.2008, 04:54 PM
Quark sent me a new 125b monster pro free of charge.  thats great customer service thanks quark
03.04.2008, 12:15 PM
Hi, Griffin.
I think you are right on the price of 125B going down in the future. Even though I didn't hear a clear answer to my question from Sky-Tech, I think that they have been affected by Mamba Monster Maxx when I heard they said "yes, we have seen it." The company didn't have a lot of workers in the office when I visited the company. Maybe, it was due to some people going on leave after a long business trips. (They had been gone for almost 2 weeks for participating in a trade show and racing events) So the guy I talked to seemed to know a lot about the company's future plan. Anyway, if you take a look at the SSB-mk3 (mk1 and mk2) the case design is much better. And when I called them today to ask about my SSB-mk2 being fixed, the guy said that they have changed the CPU and did other upgrades for my ESC for free. If you let me know about your thoughts on possible upgrades to Monster 125B, I will let them know about it.
Thank you. ^^
03.04.2008, 06:19 PM
what exaclty is a 'super hv esc'?
lets say it would be able to deal with 200A constant and whatever burst and up to 8-10s lipos... good heatsink bolt on.. or watercooling ready ... i guess i would easily pay up to 400$.
rhylsadar
| Thread Tools |
| Display Modes |
Rate This Thread |
Hybrid Mode
