Serum
Serum's Avatar
09.04.2005, 04:02 PM
Hey! i allmost forgot! i even got the samples for a balancing IC.... (i wanted to make one too, untill i saw the polyquest)
but the polyquest does do something of balancing..
that 4.25 volts is the peak, 4.15 is the cutoff i thought..
That 2-5 cell TP balancer for about 50 dollars is not really expensive.. I personally won't boughter building one when that one is available.. If you are interested in those IC's..? (smd if i remember correctly, i will dig them up and check the type if your interested)
That TP has got a 4.3V overvoltage warning, i thought 4.15 was the maxximum..?
