03.09.2008, 06:15 PM
I guess it depends on what people's definition of "warm" is. I typically shoot for temps no higher than 50-60*F above ambient max. So, if it's 80* outside, 140*F is the max I like. For some, this is just warm. To me, that is hot. Don't forget, electronic components have a temperature derating factor; the hotter it gets, the less current it is rated to pass.
rchippie
rchippie's Avatar
03.09.2008, 06:23 PM
I run a 7s motor on 2s lipo with a 12/46 or 13/46 gear & a MM with 2.2 truck tires , & the temps are great so far.
REAL MEN RUN BRUSHLESS
nitrorube
nitrorube's Avatar
03.09.2008, 11:51 PM
ok brian if your out there,how about a 6l,i was using the speed calculator and this motor has what i want,but will it get hot,going to try 18 tooth with 2 cell,what do you think,i value your opinion,thanks
FG101C
03.10.2008, 12:05 AM
To me warm is about 450 degrees F.
