Gee
A Horse's Ass
Gee's Avatar
03.15.2008, 06:03 AM
Man that looks clean. The spur does look better setting farther back. To me it looks correct setting back like that. The pics I posted above were just a FYI for anyone that might want to used the 3905 shaft and leave it the original length. I drilled the exit hole on the other side of the case. You can see it in the second picture. If you change spurs a lot that hole on the end of the shaft sure makes it easier. Next time I have my evo apart I might do what you did. The neu has a long shaft so it works well as is but I like the trimmed look. Did you use the revo shaft on yours?
